1978 Terramite 4 Hydrulic problem
/ 1978 Terramite 4 Hydrulic problem #1
Pkil4483
1978 terramite 4
1978 terramite 4 loosing Hydrulic pressure after about 20 minutes of working time, but always trams good. I’m thinking it’s the vane pump but not for sure. Anyone have any ideals?
/ 1978 Terramite 4 Hydrulic problem #2
Does it tram well even if it's a hill or over an obstacle that requires pressure? If you're only losing curl/cylinder function you might have a sticky relief though you should be able to hear it squealing.
It sounds like you're building up heat in the fluid maybe. Open all the access panels and get a thermometer gun. Look for temp spikes at relief valves and pumps.
