1978 Terramite 4 Hydrulic problem
/ 1978 Terramite 4 Hydrulic problem #1
Pkil4483
1978 terramite 4
1978 terramite 4 loosing Hydrulic pressure after about 20 minutes of working time, but always trams good. I’m thinking it’s the vane pump but not for sure. Anyone have any ideals?
/ 1978 Terramite 4 Hydrulic problem #2
Does it tram well even if it's a hill or over an obstacle that requires pressure? If you're only losing curl/cylinder function you might have a sticky relief though you should be able to hear it squealing.
It sounds like you're building up heat in the fluid maybe. Open all the access panels and get a thermometer gun. Look for temp spikes at relief valves and pumps.
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
2019 K&K Equipment Trailer, VIN # 1K9PE2026KA175452 (A65563)
2019 K&K Equipment...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
AR500 Coyote Target (A65640)
AR500 Coyote...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2017 International 4300 Box Truck (A62613)
2017 International...
