1970's JD 310B (engine block heater)
   / 1970's JD 310B (engine block heater) #1
Aruba1
Remlap, AL
Ford Dexta, JD310B, Case 850B
Hi,
I am looking for an engine block heater for my john deere 310 A or B. It's the 3 cylinder diesel engine. I can't find a stock block heater, does anyone have any recommendation of what type will fit my block? Thanks
   / 1970's JD 310B (engine block heater) #4
Technically one can not use a block heater but can use a canister heater similar to photo.
   / 1970's JD 310B (engine block heater) #6
Yes that coolant heater should be ok.
   / 1970's JD 310B (engine block heater) #7
Technically that image of the tank heater is too high. The hot coolant from the heater should not travel "downhill" into the engine.
   / 1970's JD 310B (engine block heater) #8
Are you referring to the photo I posted?
Jim
Can you ya'll educate me why a block heater is a bad idea? Thanks
   / 1970's JD 310B (engine block heater) #10
No freeze(expansion) plug hole available to install a block heater on a 310B engine.
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
72'' power rake (A53421)
72'' power rake...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2017 Chevrolet Tahoe (A52377)
2017 Chevrolet...
