1970's JD 310B (engine block heater)
   / 1970's JD 310B (engine block heater) #1
Aruba1
Remlap, AL
Ford Dexta, JD310B, Case 850B
Hi,
I am looking for an engine block heater for my john deere 310 A or B. It's the 3 cylinder diesel engine. I can't find a stock block heater, does anyone have any recommendation of what type will fit my block? Thanks
   / 1970's JD 310B (engine block heater) #4
Technically one can not use a block heater but can use a canister heater similar to photo.
   / 1970's JD 310B (engine block heater) #6
Yes that coolant heater should be ok.
   / 1970's JD 310B (engine block heater) #7
Technically that image of the tank heater is too high. The hot coolant from the heater should not travel "downhill" into the engine.
   / 1970's JD 310B (engine block heater) #8
Are you referring to the photo I posted?
Jim
Can you ya'll educate me why a block heater is a bad idea? Thanks
   / 1970's JD 310B (engine block heater) #10
No freeze(expansion) plug hole available to install a block heater on a 310B engine.
1065 (A53342)
1065 (A53342)
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
RV Hitch (A50121)
RV Hitch (A50121)
2009 Wells Cargo 5th Wheel Office Trailer (A53117)
2009 Wells Cargo...
3 Cameras (A51695)
3 Cameras (A51695)
