1970's JD 310B (engine block heater)
   / 1970's JD 310B (engine block heater) #1
Aruba1
Remlap, AL
Ford Dexta, JD310B, Case 850B
Hi,
I am looking for an engine block heater for my john deere 310 A or B. It's the 3 cylinder diesel engine. I can't find a stock block heater, does anyone have any recommendation of what type will fit my block? Thanks
   / 1970's JD 310B (engine block heater) #4
Technically one can not use a block heater but can use a canister heater similar to photo.
   / 1970's JD 310B (engine block heater) #6
Yes that coolant heater should be ok.
   / 1970's JD 310B (engine block heater) #7
Technically that image of the tank heater is too high. The hot coolant from the heater should not travel "downhill" into the engine.
   / 1970's JD 310B (engine block heater) #8
Are you referring to the photo I posted?
Jim
Can you ya'll educate me why a block heater is a bad idea? Thanks
   / 1970's JD 310B (engine block heater) #10
No freeze(expansion) plug hole available to install a block heater on a 310B engine.
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
1267 (A50490)
1267 (A50490)
2013 Ford F-350 Pickup Truck (A53117)
2013 Ford F-350...
