1970's JD 310B (engine block heater)
   / 1970's JD 310B (engine block heater) #1
Aruba1
Remlap, AL
Ford Dexta, JD310B, Case 850B
Hi,
I am looking for an engine block heater for my john deere 310 A or B. It's the 3 cylinder diesel engine. I can't find a stock block heater, does anyone have any recommendation of what type will fit my block? Thanks
   / 1970's JD 310B (engine block heater) #4
Technically one can not use a block heater but can use a canister heater similar to photo.
   / 1970's JD 310B (engine block heater) #6
Yes that coolant heater should be ok.
   / 1970's JD 310B (engine block heater) #7
Technically that image of the tank heater is too high. The hot coolant from the heater should not travel "downhill" into the engine.
   / 1970's JD 310B (engine block heater) #8
Are you referring to the photo I posted?
Jim
Can you ya'll educate me why a block heater is a bad idea? Thanks
   / 1970's JD 310B (engine block heater) #10
No freeze(expansion) plug hole available to install a block heater on a 310B engine.
2018 Kubota RTV-X1100C 4x4 Diesel Utility Cart (A51694)
2018 Kubota...
2012 Mitsubishi Outlander Sport AWD SUV (A51694)
2012 Mitsubishi...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
More info coming soon! (A50322)
More info coming...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
