1963 Case 530CK Backhoe/Loader
/ 1963 Case 530CK Backhoe/Loader #201
comparing descriptions from previous posts i believe it is a model 32 loader, and post 64 tractor from what you said about the steering pistons.
/ 1963 Case 530CK Backhoe/Loader #202
I bought a 1963 530 CK backhoe recently .Hydraulics seem to work well . I have replaced some hoses-not fun but not terrible.When I tried to service it,the hydraulic filter housing (right side in front of battery) was dry,not even a film of oil.This is a torque converter model.Tempted to just close it up and use it but I hate to go without a filter
/ 1963 Case 530CK Backhoe/Loader #203
Good to see that you found this thread. There is a wealth of 530 CK information here and some knowledgeable folks. Hopefully they will chime in. I've no idea on your filter problem but just wanted to post so as to follow along and maybe learn something.
rScotty
/ 1963 Case 530CK Backhoe/Loader #204
rScotty
Thanks! It looks like a really good site.Unfortunately,I always seem to come up with something no has ever seen before
/ 1963 Case 530CK Backhoe/Loader #205
Do you think that the filter was bypassed for some reason? I've never seen that before, but not too hard to do. Just odd....
Most filters are on the suction side of the hydraulic pump and some have an internal bypass to prevent starving the hydraulic pump. If you have a hydraulic chart for your machine & post it we could see if anyone has an idea.
/ 1963 Case 530CK Backhoe/Loader #206
Been hauling anhydrous for a few days. I appreciate your reply. Ill try to find a hydraulic chart. The thing is it works so well I never would have guessed there was a problem. Might just close it up,use it and keep thinking about.
/ 1963 Case 530CK Backhoe/Loader #207
Open this link, I think you'll find it quite handy. It is a service and parts manual for the 530 which includes tractor, backhoe and loader: Case 530CK - Manuals
To find parts use the OEM part number, if on a PC copy and paste the part number to Google, you'll be amazed what pops up. Do a separate search on ebay too.
/ 1963 Case 530CK Backhoe/Loader #208
I started the tractor today with the filter housing open and no filter.Raised the loader all the way up,no leaks. Going to close it up and forget about it for now. Thanks for the input
/ 1963 Case 530CK Backhoe/Loader #209
Thank you, I will look into it
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
2015 Ford F-150 IN-OP at time of listing (A63118)
2015 Ford F-150...
