1942 d4 CAT
/ 1942 d4 CAT #1
dlopez
Kubota RTV 1100
I have had a problem with the trans oil leaking out of my '42 d4 dozer. It is coming out of a hole on the bottom of the trans and I don't know if that is a bell housing drain or if it is missing the plug. It only leaks a little at a time due to a sponge like material holding most of it in. If anyone knows if I need to plug that or if my main seal is shot and that's why its leaking, please give me your advise. Thanks.
/ 1942 d4 CAT #2
I've been running my Dad's 1951 Allis Chalmers HD5 (about the size of a Cat D3) for a couple of months and it has pretty much the same problem. I suspect a seal is bad, but considering its age and that it still runs like a top, I just add 80-90 gear oil once a week and call it good. If I was relying on it in a business situation I would certainly have it fixed. For my occasional use a little spilled oil is nothing to worry about.
I did not answer your question, but I hope this helps.
/ 1942 d4 CAT
That is almost exactly what I do, just add 80-90 every time I use it which is occasional. IT runs like a champ and does amazing! I love it and at some point will fix it. Thanx for the confidence that wat I'm doing isn't very bad.
1207 (A64280)
1207 (A64280)
2023 73in Vibratory Roller Skid Steer Attachment (A61572)
2023 73in...
2016 Nissan NV2500 Cargo Van (A61573)
2016 Nissan NV2500...
2022 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A61572)
2018 Caterpillar...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
