1942 d4 CAT
/ 1942 d4 CAT #1
dlopez
Kubota RTV 1100
I have had a problem with the trans oil leaking out of my '42 d4 dozer. It is coming out of a hole on the bottom of the trans and I don't know if that is a bell housing drain or if it is missing the plug. It only leaks a little at a time due to a sponge like material holding most of it in. If anyone knows if I need to plug that or if my main seal is shot and that's why its leaking, please give me your advise. Thanks.
/ 1942 d4 CAT #2
I've been running my Dad's 1951 Allis Chalmers HD5 (about the size of a Cat D3) for a couple of months and it has pretty much the same problem. I suspect a seal is bad, but considering its age and that it still runs like a top, I just add 80-90 gear oil once a week and call it good. If I was relying on it in a business situation I would certainly have it fixed. For my occasional use a little spilled oil is nothing to worry about.
I did not answer your question, but I hope this helps.
/ 1942 d4 CAT
That is almost exactly what I do, just add 80-90 every time I use it which is occasional. IT runs like a champ and does amazing! I love it and at some point will fix it. Thanx for the confidence that wat I'm doing isn't very bad.
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
26ft. Truck Box Body (A61573)
26ft. Truck Box...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2012 Gastron 18ft Boat w 18ft S/A Boat Trailer. (A61574)
2012 Gastron 18ft...
