18x30 Carport
   / 18x30 Carport #1
TXA
Mahindra
Just checking to see if anyone has built anything similar and if you used anything similar in beam size, etc? I haven't built it yet but would like to so any advice is appreciated.
   / 18x30 Carport
IMG_20190528_144419484.jpg Sorry, didn't attach the pic the first time!
   / 18x30 Carport #3
Everything looks fine, but I would tie the 2x6 into the into a double 2x10 on the high and low side. Depending on where you live will be the big reason for determining pitch and spacing on the rafters . Once all that is tied in, I would mount 1x4s to the top of the 2x6 no more than 3 ft apart going up the rise. You can let the tin stick out 6 inches over the boards length wise. They can also width wise that much as long as there is a 1x4 under it.
   / 18x30 Carport #4
Will the 2x6 span that 18 feet? I am doing something similar for a lean to and thought 12-14 ft was as far as I could get.
   / 18x30 Carport #5
A 2x6 would handle the weight of the roof fine. If you can’t find them in that length you could scab 2 together or use 2x8. The only problem I have have getting 2x6 was when I needed 18 ft treated ones to replace the floor in my utility trailer. A lot of places I called had untreated 2x6 in that length. I found one place that had the 2x6x18 treated in stock.
   / 18x30 Carport #6
Lenny, with you being in Vermont, your calculator might be determining for snow load. You would want a higher pitch to help shed snow and ice better. I’m not real familiar with snow loads so maybe someone that is could tell you more accurately than myself.
   / 18x30 Carport #7
Have you considered steel?
   / 18x30 Carport
Thanks. Just to make sure I'm understanding, I should double the 2x10 on the 30 foot side and put in something like a rafter hanger to attach them to the beam?
   / 18x30 Carport
I was just going to connect 2 lengths together somehow. I live in central Texas, no snow loads and rain is only heavy in some years.
   / 18x30 Carport
For the design, it wouldn't have the aesthetics we're looking for. Of course, if it falls to pieces, it won't look much better :)
   / 18x30 Carport #11
Yes a rafter hanger will be easier than trying to toenail them together. If you can’t find 2x6x18, you can take a foot long 2x6 and scab to one side or both sides to connect both 2x6 together. Before they came out with the metal brackets on trusses, that’s how old ones were tied together. If you don’t like the way the scab patch looks, you can nail a foot or 2 of the 2x6 together. A lot of barns have been built that way around here.
   / 18x30 Carport #12
Doubling the 2x10 will keep it from trying to sag when it gets alittle age to it and gives you more to secure the 2x6 to.
   / 18x30 Carport
Thanks to all the replies and info! I'll post up the results as they come if anyone is interested. So far I have one side of the post anchors set in concrete. That's about it.
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
SWICT 66" SKID STEER BUCKET (A60430)
SWICT 66" SKID...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
