1736 Reduced Power with PTO Engaged
/ 1736 Reduced Power with PTO Engaged #1
zdman
Whitewright, TX
Massey 1736
I am having an issue with my 1736 while running the pto. The issue recently started - basically any time I run the pto (brush hog or tiller) the tractor seems to bog down. For example, I normally run the tiller at 540 RPM and in midrange gear 3 or 4. Now it bogs the tractor down and I have to move to the low gear range in gear 3. Same with the brush hog., I have to use a lower gear than I was using before. Otherwise, tractor runs fine and no issues including FEL operation.
