1723e RPM issues
   / 1723e RPM issues #1
Bcwoods
Massey Ferguson 1723
Had the engine control relay go out in my tractor. Installed new one and now the tractor wont rev past 2000rpm. No issues with the cable. The throttle linkage has full range of movement. Not sure what would cause this.
   / 1723e RPM issues #2
Sounds like fuel or air starving.
   / 1723e RPM issues #3
you talking about the fuel control solenoid? don't know of anything else that could be called the engine control relay.
if so bet you got air in system.
   / 1723e RPM issues
This is the part number to what I replaced. 6253541M91 It started off with my alternator going out. Replaced it. Then the accessory fuse kept blowing and I traced the short down to the engine control relay that I replaced. I’ve drained the fuel tank, changed fuel filter, blew out all fuel lines, bled air out of fuel system and still can only rev to 2000 rpm. I know there is not much to these engines but it’s got me puzzled.
   / 1723e RPM issues #5
oh that, sorry missed that. iirc that only controls signal to the fuel solenoid depending on key position.
with the key on engine off is the pickup pump chattering as it should?
   / 1723e RPM issues
Yea the pump chatters as it should
   / 1723e RPM issues #7
as far as I know the solenoid powered by that relay is either open or shut, no in between so can't see that relay short messing with that. fact it comes up to 2K rpm leads me to think thats ok.
assume the tank/line work was done due to this new problem of only hitting 2k correct?
did you crack lines on pump and injectors to bleed ?
just for grins remove fuel cap see if works fine, prob won't matter though. maybe remove air filter also. this checks tank venting and for restricted airflow.
   / 1723e RPM issues
Yea I cracked top of I injectors to make sure no air. Not sure if the factory fuel pump isn’t putting out enough fuel to keep up due to an internal issue in the pump. It’s only rated to put out .01 gpm. Any restriction with that may be part of the issue. I’ll try a few things and see what happens.
   / 1723e RPM issues
Still same result. Installed a new fuel pump that puts out .05 gpm. Double checked air bleed. Still tops out at 2k rpms. Ugh!
   / 1723e RPM issues #10
Are you sure your tachometer is accurate?
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2008 Keystone Camper Mod. 311BHS (A59814)
2008 Keystone...
Heavy Duty 4-Way Lug Wrench (A57454)
Heavy Duty 4-Way...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
