1723e RPM issues
   / 1723e RPM issues
Are you sure your tachometer is accurate?
That’s what I was getting ready to add to this post. I purchased a digital tach. Throttled up to full power, engaged rear pto and rear pto reads around 680rpm. So at full throttle that’s probably accurate so now I assume the dash tach is messed up at higher rpm. It reads correct idle of 900. So I guess when the alternator fried it messed up the dash cluster as well.
   / 1723e RPM issues #12
If I remember right (jese I was just messing with one 3 days ago you think I can remember????) rpm section of tach is mechanical, only hour meter electric.
did you try with air filter and fuel cap removed yet? costs nothing takes 5 minutes. rule out airflow and tank vent issues.
   / 1723e RPM issues
I did the air filter and fuel cap check. The dash cluster is all electric. While running I can remove plug from behind dash cluster, tach and hour meter go off.
   / 1723e RPM issues #14
maybe what I thought was mech cable was harness then.
   / 1723e RPM issues #15
gc2400 mechanical tach the 540 mark is just over 2500rpm, I rev limit at approx 2850 +/- rpm so 680rpm is prob dead on.
ug thats about 590$ for new one.
500 GALLON FUEL TANK ON SKID (A52708)
500 GALLON FUEL...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3 Ton Crane Service Truck (A55973)
2017 Ford F-550...
1000 GALLON PROPANE TANK (A52708)
1000 GALLON...
Black Metal Roof Panels (A55758)
Black Metal Roof...
1997 Ford E250 Cargo Van (A56858)
1997 Ford E250...
