1723e RPM issues
/ 1723e RPM issues #1
Bcwoods
Massey Ferguson 1723
Had the engine control relay go out in my tractor. Installed new one and now the tractor wont rev past 2000rpm. No issues with the cable. The throttle linkage has full range of movement. Not sure what would cause this.
/ 1723e RPM issues #2
Sounds like fuel or air starving.
/ 1723e RPM issues #3
you talking about the fuel control solenoid? don't know of anything else that could be called the engine control relay.
if so bet you got air in system.
/ 1723e RPM issues
This is the part number to what I replaced. 6253541M91 It started off with my alternator going out. Replaced it. Then the accessory fuse kept blowing and I traced the short down to the engine control relay that I replaced. I’ve drained the fuel tank, changed fuel filter, blew out all fuel lines, bled air out of fuel system and still can only rev to 2000 rpm. I know there is not much to these engines but it’s got me puzzled.
/ 1723e RPM issues #5
oh that, sorry missed that. iirc that only controls signal to the fuel solenoid depending on key position.
with the key on engine off is the pickup pump chattering as it should?
/ 1723e RPM issues
Yea the pump chatters as it should
/ 1723e RPM issues #7
as far as I know the solenoid powered by that relay is either open or shut, no in between so can't see that relay short messing with that. fact it comes up to 2K rpm leads me to think thats ok.
assume the tank/line work was done due to this new problem of only hitting 2k correct?
did you crack lines on pump and injectors to bleed ?
just for grins remove fuel cap see if works fine, prob won't matter though. maybe remove air filter also. this checks tank venting and for restricted airflow.
/ 1723e RPM issues
Yea I cracked top of I injectors to make sure no air. Not sure if the factory fuel pump isn’t putting out enough fuel to keep up due to an internal issue in the pump. It’s only rated to put out .01 gpm. Any restriction with that may be part of the issue. I’ll try a few things and see what happens.
/ 1723e RPM issues
Still same result. Installed a new fuel pump that puts out .05 gpm. Double checked air bleed. Still tops out at 2k rpms. Ugh!
/ 1723e RPM issues #10
Are you sure your tachometer is accurate?
/ 1723e RPM issues
That’s what I was getting ready to add to this post. I purchased a digital tach. Throttled up to full power, engaged rear pto and rear pto reads around 680rpm. So at full throttle that’s probably accurate so now I assume the dash tach is messed up at higher rpm. It reads correct idle of 900. So I guess when the alternator fried it messed up the dash cluster as well.
/ 1723e RPM issues #12
If I remember right (jese I was just messing with one 3 days ago you think I can remember????) rpm section of tach is mechanical, only hour meter electric.
did you try with air filter and fuel cap removed yet? costs nothing takes 5 minutes. rule out airflow and tank vent issues.
/ 1723e RPM issues
I did the air filter and fuel cap check. The dash cluster is all electric. While running I can remove plug from behind dash cluster, tach and hour meter go off.
/ 1723e RPM issues #14
maybe what I thought was mech cable was harness then.
/ 1723e RPM issues #15
gc2400 mechanical tach the 540 mark is just over 2500rpm, I rev limit at approx 2850 +/- rpm so 680rpm is prob dead on.
ug thats about 590$ for new one.
Bear Statue (A64557)
2002 Built Rite Utility Trailer (A66285)
2002 Built Rite...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
1980 19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A64557)
1980 19ft Sailboat...
Pallet of 8ft Metal Roofing (A65583)
Pallet of 8ft...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A67147)
2020 FREIGHTLINER...
