1705 antifreeze question
/ 1705 antifreeze question #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Bought a used 1705 in July checked my antifreeze today to see how low my temp on my antifreeze checker said, and it said +10 degrees. And the radiator is full should I run it a bit and recheck or go ahead and drain some out and add more anti-freeze to get it down to -10 or-20 for the winter? I live in central Illinois, and it does get pretty cold sometimes with the wind chill. The tractor will be garage kept but I was worried about out in the weather pushing snow.
/ 1705 antifreeze question #2
I would just flush and refill with a 50/50 mix. But you could drain some out and add straight antifreeze.
/ 1705 antifreeze question #3
All sorts of options.
First, wind chill is one of my pet peeves: We all know it feels colder with wind. Most of the public is misinformed, off quoting all kinds of nonsense about how cold they heard it was, etc. mixing numbers because the TV stations use wind chill and "feels like" to create something that sounds more exciting. It sells TV watching better. I'd be happy if they were prohibited from quoting wind chill numbers and EVERYONE would be better off.
In your case, for the innards of a tractor cooling system, wind chill is irrelevant and has no meaning. No wind inside your radiator. But that said, you guys in central Ill. sometimes (not a lot) get zero and subzero real thermometer temperatures, right? If you can rely on it being in the garage overnight all winter you probably do not need to do anything -- that is unless you think it is going below 10 deg in your garage. Of course Peter is right in suggesting the overall standard recommendation for the entire country -- flush and refill with 50/50 -- which gives you a 34 below freezing point. By the way, once the tractor is warmed up some there is no danger of the coolant freezing, though it possibly could in VERY extreme cold in the radiator because the thermostat might be closed for a while not circulating into the radiator.
I see nothing in the world wrong with removing a quart or so of your coolant and refilling with 100% antifreeze. That will lower your freezing point several degrees and you'd be fine for the winter because of your situation using the garage. You may even have a little heat in the garage in the most severe weather? Obviously draining a lot more and replacing with 100% antifreeze will give you more margin until you reach the 50/50. Watch out as they are selling 50/50 mix in jugs these days.
Probably the practical question is "When was the antifreeze last changed and should it be flushed and refilled anyway?" If it is old (and it probably is because no one is going to flush it and fill it to only have a +10 freezing point) then Peter is right and the best answer is just have it over with -- flush and refill.
But this whole thought process raises what MAY be a more important question: Why did prior owners have the cooling system apart, put in a bunch of water and then only enough antifreeze to give +10 freezing point? I would press that question hard with the previous owner first.
/ 1705 antifreeze question #4
I would also just drain and refill to 50/50. In the garage is where a freezing problem may exist. Out plowing snow would be a non issue.
Well, I did contact the old owner on why the antifreeze was +10 degrees and he said that his plastic reserve tank developed a crack and a lot leaked out. So, he bought another plastic tank and just refilled the radiator with water. He also said the tractor was always kept in a heated shed and it does have a block heater on the engine which I noticed when I bought the tractor.
  • Good Post
Reactions: JWR
/ 1705 antifreeze question #6
A block heater isn’t meant to prevent coolant from freezing….🤷
/ 1705 antifreeze question #7
Why not? It is meant to make the engine easy to start in very cold weather but a block heater will heat the coolant inside the block which by conduction heats everything it is in contact with. Coolant is prevented from freezing though that may not be the primary intent of the block heater. Coolant far enough away from the block (like out in the radiator) could still potentially freeze if not a high enough % antifreeze of course. I always liked the circulation type heaters that pulse warm coolant through the radiator and the block and the entire circuit. A reason to prefer circulation type over the block heaters.
/ 1705 antifreeze question #8
GC series block heater can take coolant from 0 to approx 50 deg in 1 hour. internals of radiator also warmed. GC series radiator is rear of engine (front of steering orbital valve) so easily gains heat from the block itself as well as the coolant warm up circuit of thermostat housing the iseki engines use.
can feel the heat on upper/lower/bypass hose and rad fins by hand after 1 hour plus temp guage is 1/8 way up.
and the point and shoot thermometer also used.
can't leave it plugged in all night as is not temp controlled, either plugged in and on or unplugged and off.
/ 1705 antifreeze question #9
Check the owners manual. Probably several years past the recommended change interval. It is the easiest service to do on a GC, and most overlooked.
/ 1705 antifreeze question #10
As a general principle, when I buy a used machine I go through and change all the fluids. That way there is no question about what or when it was changed. It’s also a ritual that goes toward making a new to me machine my machine.
/ 1705 antifreeze question #11
Well not quite. The circulation heaters are limited what they circulate/heat by the thermostat and only in an extreme case would the thermostat open…
/ 1705 antifreeze question #12
Nope, doesn't work that way. The circulation type heaters get installed in the lower radiator hose and pulse heated liquid through the circuit. I hear you about the thermostat (and makes me wonder how the liquid can circulate initially while cold) but I know this: I installed one in a VW diesel wagon and it worked like a charm. The entire engine and radiator got warm. Obviously they work somehow otherwise circulation heaters could not and would not have been sold. Sears sold them back in the 1980's. They are sold today by others.
Ok I drained some anti-freeze out of the 1705 prob about 1/2 gal or so added straight anti-freeze ran it for about 20 min got it nice and warm rechecked the freezing point and it now down to -25 Thanks everybody for all you help!!!
  • Good Post
Reactions: JWR
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
(2) Lights (A64119)
(2) Lights (A64119)
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 Mercedes-Benz Sprinter 1500 Cargo Van (A61573)
2022 Mercedes-Benz...
iDrive TDS-2010H...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
