1700 temp light
/ 1700 temp light #21
You might want to do a search of this forum for this. A number 1700 owners have detailed their saga's here including myself with the 1700 temp light.
I ended up replacing the idiot light with a temp gage...Problem solved. I got the gauge from Hoye as well..
I have come to the conclusion that as long as the outside temperature is below 80 degrees mine runs between 140 - 160 degrees. When the outside temp gets 90+ it will run between 170-190...When the engine temps gets above 190 it usually means I need to clean the radiator screen.
/ 1700 temp light
The switch,110-C came in from hoye's put it on .Hooked up the Cultivator to the YM 1700 ran it for about and hour .The light never came on so that fix that.Thanks ever one.
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2022 Horizon Trailer (A55973)
2022 Horizon...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
Kuhn FC400RG (A60462)
2005 Peterbilt 387 with Wet Kit (A61307)
2005 Peterbilt 387...
2023 FONTAINE INFINITY FLATBED TRAILER (A59823)
2023 FONTAINE...
