1700 temp light
/ 1700 temp light #21
You might want to do a search of this forum for this. A number 1700 owners have detailed their saga's here including myself with the 1700 temp light.
I ended up replacing the idiot light with a temp gage...Problem solved. I got the gauge from Hoye as well..
I have come to the conclusion that as long as the outside temperature is below 80 degrees mine runs between 140 - 160 degrees. When the outside temp gets 90+ it will run between 170-190...When the engine temps gets above 190 it usually means I need to clean the radiator screen.
/ 1700 temp light
The switch,110-C came in from hoye's put it on .Hooked up the Cultivator to the YM 1700 ran it for about and hour .The light never came on so that fix that.Thanks ever one.
Champion X18A Air Compressor (A65640)
Champion X18A Air...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
1,000 gal Stainless Tender Tank (A66408)
1,000 gal...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
