1700 temp light
/ 1700 temp light #21
You might want to do a search of this forum for this. A number 1700 owners have detailed their saga's here including myself with the 1700 temp light.
I ended up replacing the idiot light with a temp gage...Problem solved. I got the gauge from Hoye as well..
I have come to the conclusion that as long as the outside temperature is below 80 degrees mine runs between 140 - 160 degrees. When the outside temp gets 90+ it will run between 170-190...When the engine temps gets above 190 it usually means I need to clean the radiator screen.
/ 1700 temp light
The switch,110-C came in from hoye's put it on .Hooked up the Cultivator to the YM 1700 ran it for about and hour .The light never came on so that fix that.Thanks ever one.
Onan 6500 Generator (A66408)
Onan 6500...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Bucket (A64194)
Pemberton Inc...
1987 FORD F-8000 ROLLBACK TRUCK (A64277)
1987 FORD F-8000...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
2015 KENWORTH T800 TRI-AXLE (A65643)
2015 KENWORTH T800...
2022 EZ-GO ELITE...
