16k trailer with 14500 payload.
   / 16k trailer with 14500 payload. #21
LD1 shared some very good information above. But we need to clarify this part:
And while you MAY have a truck that can handle the 3350# tongue weight.....the problem is the load will probably need shifted forward enough that you will actually overload the FRONT axle of the trailer. Like maybe 8k on the front axle and 6k on the rear and 3350 on the hitch.
For this to be true you would have to rotate the oscillator to the max angle. Which will be almost impossible. Until the oscillator rotates to it's max angle the weight percentage on each axle does not change. If the original design was to share the load between the two axles 50% to 50%, that remains regardless where the weight is on the trailer. The axles actually are not affected by the location of the load on the trailer floor. They are only affected by the load placed on the oscillators.
  • Good Post
Reactions: bgr
Thanks for all the replies! I'm going to call them today.
   / 16k trailer with 14500 payload. #23
synthetic grease(y)
My old GN trailer has oil bath axles. After having seals go bad twice and soaking the brakes with oil I switched to grease.
I use JD Polyurea Grease. It is designed for extreme load, high temperature, high speed loads with a temperature range of -15F to 380F.
The reason for oil bath bearings is they pull slightly easier. Something you would never detect. But after a million miles of use on a commercial trailer it would have a measurable difference in "power" required, thus fuel savings.
   / 16k trailer with 14500 payload. #24
Makes me wonder what the actual profit margins are for the cardboard and staples that passes for an RV these days
Lots lots lots. LOL
I used to haul brand new RV trailers from the factories back in 2008. So I got to see all the paperwork.
Back then even with the $80,000 trailers there were none that were over $25,000.
I'd say that is a pretty good markup.
In 2005 I bought a 27 footer to tow behind the dump truck in my avatar when I worked out of town. It was $31,000 on the lot. dealer "gave" it to me for $24,000. I thought wow, what an awesome dealer! Until I started hauling them to dealers with my highway truck and found out it was a $15,000 trailer, LOL
   / 16k trailer with 14500 payload. #25
Lots lots lots. LOL
And the same thing is happening with new vehicles.
   / 16k trailer with 14500 payload. #26
That may be true. And I have heard that before that sharing equal load is how they are "supposed" to work.
Based on my unscientific observations with different loads, and loading and unloading equipment, and observing tire sidewall flex....I think equal loading is just theory.
I actually have to see a trailer on scales and moving a load and observing the results to actually believe it.
   / 16k trailer with 14500 payload. #27
If it's not a spec typo, it sure seems like deliberate deception on the part of the manufacturer which would make me wonder what else they are being deceptive on
I've heard of manufacturers using "unsprung weight" by subtracting the weight of the running gear for example
   / 16k trailer with 14500 payload. #28
I've never tested this mathematical theory with a scale. But mathematics don't lie. The design is to intentionally equalize the load on the axles. Until the oscillator reaches it's limit. Then everything changes.
If this theory doesn't hold up, then an over the road trailer that slides the trailer axles would quickly overload the front trailer axle or the rear trailer axle. And the DOT scales would have to weigh each axle separately to determine if they were legal. Which they do not. :)
   / 16k trailer with 14500 payload. #29
These incidents are "word salad". Commonly used in advertising today.
I understand "unsprung weight" very well. In this discussion the only weight that doesn't have an impact on the axle's ability to carry it would be the tires/wheels/hub assemblies. Everything from the wheel bearings up, including the weight of the bearings, counts against the axle's capacity.
DOT doesn't give us that tolerance though. Because they are concerned about the amount of weight applied to the roadbed.
   / 16k trailer with 14500 payload. #30
I dunno. But I think semi's axles are not really the same design....
I get the "theory" of equalizing the load. And they do when compared to a torsion axle or independent axles.
But the fact that they are only "equalizing" the load placed on the middle hanger. The weight on that center bolt of the equalizer is indeed shared equally between both front and rear axle.
But the front eye of the front axle and rear eye of the rear axle springs are not shared.
I have not been able to find anything at all or any sources that state BOTH axles have equal weight in a tandem trailer with equalizer/double-eye springs.
I HAVE been able to find people posting that when scaling their tandem trailer with this type of suspension that they are seeing HIGHER front axle loads than rear (on an empty trailer). Which makes sense because they are tongue heavy when empty.
So while I think: That the load placement on the trailer does indeed change individual axle loads.....the point of the equalizer is NOT to make the weights equal. The point is to make the weights of the individual axles NOT CHANGE when going over bumps or uneven terrain.
I could be way off.....but have yet to find definitive proof either way. Just my real-world observations.
But not trying to get off topic.......to the OP......if you want to haul 14.5k.....RUN AWAY from ANYTHING with dual 7k axles PERIOD
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2017 Mitsubishi Outlander Sport SUV (A55758)
2017 Mitsubishi...
KMC 5610 (A53084)
KMC 5610 (A53084)
2018 Ford Transit Cargo Van (A55852)
2018 Ford Transit...
Towable Orchard Sprayer (A55851)
Towable Orchard...
2022 PETERBILT PB337 DUMP TRUCK (A52706)
2022 PETERBILT...
