1635 PTO issue
   / 1635 PTO issue #1
EricMF1635
Was bush hogging today and my PTO stopped turning. Check level to make sure it didn稚 get knock to neutral but it痴 fine. Any ideas?
   / 1635 PTO issue #2
According to TractorData, you have electro-hydraulic PTO.
Basically, you select the PTO gear you want and flip a switch to turn it on. What happens a lot during bushhogging is that sticks, heavier brush and whatever can pull the wires under the tractor and cause all sorts of problems.
You may want to give a closer look under the tractor for any pulled wires. Also check the fuses.
   / 1635 PTO issue
Yep, that痴 exactly what happened. Wire pulled lose under tractor!
   / 1635 PTO issue #4
I'm glad it was an easy fix. Thanks for updating us. :thumbsup:
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2014 Nissan Frontier Ext.Cab Pickup Truck (A50323)
2014 Nissan...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
Bobcat 72BRSHCT Hydraulic 72in Brush Cutter with Skid Steer Plate Attachment (A50322)
Bobcat 72BRSHCT...
40' Sea Container (A50774)
40' Sea Container...
