1635 Box Blade
   / 1635 Box Blade #1
crreed67
Central WV
Massey Ferguson 1635
I've been reading posts for 3 days now and need help. Need box blade recommendations for occasionally grading 1600 ft gravel driveway and some varying minor grade work and dirt moving on about 6 acres. I'm not sure how heavy I can go or which brand would be the better for whatever weight all of you experts recommend. I have a Massey Ferguson 1635 HST/Cab with washer fluid filled R4 rear tires and a FEL with a 72" bucket. I like the Land Pride, Bush Hog and Everything Attachments box blades but am open to all suggestions and information, especially on size and weights. Thanks for a great Forum.
   / 1635 Box Blade #2
You have the weight/power more like a MF35 so it would be my guess a light 6' might work out well. If moving dirt very far I would try to get a couple box full into the FEL and then drag the one.
   / 1635 Box Blade #3
A 6 footer is perfect for your tractor. Typically the heavier it is, the better that it will work. Best to get one that is built heavy vs getting a light weight unit and adding weight. The lighter units just are not as strong as the heavier ones. I personally would not even consider anything that wasn't at a minimum of 125lbs per foot of width. If I were looking for a unit, I would think hard about getting a roll over box blade as I have now.
Depending on your budget, but with 1600' of driveway to maintain, you might want to consider getting one of these just to maintain your drive. Very hard to beat one of these for road maintenance IMO.
Don't get me wrong, a box blade is an invaluable implement to have and will do your drive. Just not as fast and easy or generally as good. As you can see, I have both.
If you have much other grading to do, you may want to think about getting a top & tilt set to make your grading that much easier and better. ;)
   / 1635 Box Blade
That grading scraper really looks like the thing to have. Now I have research to do on another implement. As far as brands go, does any one stand out or are they all going to be similar in build and weight? Guess I'll go with a 6 footer as MtnViewRanch said but now I have to figure out which one is the heaviest that I can handle. Thanks for all the help fellows!
   / 1635 Box Blade #6
The 1635 will lift a crazy amount, 2200 at the link ends?
Stay away from TSC junk, hit a tractor dealer, Farm King, Land Pride, MF too .
Forget the box blade, get a scraper.
   / 1635 Box Blade
My MF dealer wants to sell me a Howse BSXEB72 but I'm not sure about the durability of it. Is my tractor strong enough to pull a heavy 6 foot box blade full of dirt?
   / 1635 Box Blade #8
Don't own a box blade, but don't see why not.
   / 1635 Box Blade
I see you have the 1635 with the Powershuttle WilliamBos. Very nice. I hope my hydro doesn't suck too much power from mine.
   / 1635 Box Blade #10
I would not think that you will have a problem. Traction may be a problem, running out of that before power.
   / 1635 Box Blade
That's good news. I'm new at this so bear with me. All information is welcome. After I decide on a rear blade I'll probably be bothering ya'll about a finish mower. Thanks again.
   / 1635 Box Blade
I like the roll over blade but it's a bit out of my budget range right now. Definitely gonna look at the grading scraper.
   / 1635 Box Blade #13
We have the MF RFM 500 rear finish mower, built by Alamo. Give them a look, nice unit.
   / 1635 Box Blade #14
This is one of the best and heaviest, but over priced IMO. :( Home | Road Boss Grader
Here is another good unit that has some weight to it.
GradeMaster Grader Blades
This type of implement seems to work pretty good no matter what size it is. But the heavier the better is almost always the case when it comes to grading. ;)
   / 1635 Box Blade
   / 1635 Box Blade
They do look good. Believe I would use the RF600. So's to cover the entire tractor width.
   / 1635 Box Blade #17
We got the 500 for the reason of it the teactor fits, the mower fits. Never a race to cut the grass, and it is only 4 inches.
   / 1635 Box Blade
I see. You make good sense. This is what I need. Information.
   / 1635 Box Blade #20
Traction as was posted it a limiting factor when moving dirt with a box blade. With 4x4 and some dirt in the FEL you should get good traction.
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Champion Vibratory Roller (A60462)
Champion Vibratory...
