Oil & Fuel 1538 filter part numbers.
/ 1538 filter part numbers. #21
Since I'm doing my 50 hour I needed filters and of course neither the owners manual or service manual had the part numbers for the filters so I had to drive to Yuba City to buy them. I thought I'd share the part numbers here. I have a 1538 gear or shuttle so the hydraulic filter may be different for the HST tractors, I don't know.
The hydraulic filter is really a Mitsubishi made filter the part number is 19642509000. I stopped by my local NAPA store and the NAPA equivalent is 7118. I paid $38.14 at the Mahindra dealer, I think this is cheaper than what NAPA wants for theirs.
The fuel filter elements of which there are two is part number 001081778R93. The NAPA equivalent part number is 3993. I paid $11.43 each and they look like they are worth maybe 50 cents if that. The Mahindra filter is very poorly and shoddily made of cheap materials. I'll be replacing that with an equivalent from NAPA next time for sure.
The engine oil filter is 006000789B91. I couldn't come up with an equivalent for that because of the oddball thread pitch used. I paid $14.71 for it so no biggie. Outside of the odd ball thread pitch, it's a nothing special filter with no anti drain back valve etc.
My guess would be that the 1538 and 1533s use the same filters as they have the same engine.
BTW when I first called the NAPA store, their computer didn't recognize any Mahindra 1500 series models so without these numbers they won't be able to help you.
I was actually searching for part numbers when I came across your post. I知 very grateful for all the info,
Thanks again.
/ 1538 filter part numbers. #22
I know this is an old thread, but I came across it after searching for a non-oem oil filter for my 4035. After my first oil change I used another OEM filter and then cut the old one apart to see what made it tick. I found that the OEM one is a cheap piece of junk. Glued cardboard end caps, cheap (widely spaced) pleats, looks like a Fram clone. I'm happy someone was able to cross these numbers to Wix, although I'm still a little confused as to which Hydraulic filter to buy since I have a Hydro Shuttle, not a true gear and not a true hydrostat. If someone could shed some light of that I'd appreciate it.
/ 1538 filter part numbers. #23
Fuel 1 - 001081778R93 , Napa 3993 , Wix 33393
Fuel 2 - E006018618D1 , Bosch F 002 H22 025
The first part numbers are factory numbers. From the pictures I've seen online it appears the hydraulic filters are Mitsubishi filters. And as stated the "main" fuel filter is a Bosch.
I'm getting ready to do my 50 hr service on my 1538 and I'm confused. The Fuel 1 P/N 001081778R93 comes up on the MahindraUSA parts site and the Reubicon site but does not show as effective for the 1538. Also, when pulling up the filter list for the 1538 on the Mahindra or the Reubicon sites, no secondary, cartridge filter at all is shown for my tractor. Just the spin-on.
/ 1538 filter part numbers. #24
Good morning
I have the 1533 hst model and wanted to change the air filter (outer) but didn't want to pay $90+ for one. Did you ever find an alternate air filter for your model?
Thanks,
John
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2012 FREIGHTLINER M2 6X4 T/A ROLLOFF TRUCK (A66091)
2012 FREIGHTLINER...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A64557)
2008 21 Ft...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
