1533
theg
Wylie Texas :)
Mahindra 1533
I was working with FEL to drag some trash out of pond. This put me in a front end down position due to bank of pond. The engine failure light came on. The engine never got hot or made any different sounds. As soon as I was on flat ground again it went off.
You most likely starved an oil level sensor due to the angle (I'm assuming that the 1533 does have such a sensor). Less likely is you actually starved the oil pump and lost oil pressure for a moment, and that loss of pressure was sensed.
Check your oil level when its that steep even a little bit low can show with it leaving the sensor
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
2019 JCB LSB72 Compact Track Loader Skid Steer (A61572)
2019 JCB LSB72...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
25026SFL (A61569)
25026SFL (A61569)
84'' SKID STEER BUCKET (A61572)
84'' SKID STEER...
