1533
theg
Wylie Texas :)
Mahindra 1533
I was working with FEL to drag some trash out of pond. This put me in a front end down position due to bank of pond. The engine failure light came on. The engine never got hot or made any different sounds. As soon as I was on flat ground again it went off.
You most likely starved an oil level sensor due to the angle (I'm assuming that the 1533 does have such a sensor). Less likely is you actually starved the oil pump and lost oil pressure for a moment, and that loss of pressure was sensed.
Check your oil level when its that steep even a little bit low can show with it leaving the sensor
