1533 no start, problem?
   / 1533 no start, problem?
That sure is different. At least its cost is so much less then the old design. Sorry I can't help on the size. (sorry for the late reply, Iv'e been on the road traveling)
At least you will get a bump up on the thread list. Maybe it would be better to start your own thread to get a bit more attention to your problem?
   / 1533 no start, problem? #42
Don't know where this will fill into the thread exactly, but here goes....
I have the same problem (May 2015) with my 2005 MF 1533. Checked fuses, seat switch, checked for water in fuel, removed fuel filter, etc. - all good. Checked voltage on 3 prong stop solenoid supply connector. The voltage (+ to -) on plunger retract prong (with key on) is good, The voltage (+ to -) on plunger insert prong (with key off) is good. Removed the two solenoid bolts (metric allen head on mine - 4 or 5mm) & took solenoid off....Tractor fired right up. I pushed plunger in on fuel injector pump to kill engine. Also killed it with the fuel shut-off on the bowl, & by killing it in high gear. No oil seems to be leaking out near the injector pump plunger but I won't really use the tractor until I get it fixed. Checked price for new solenoid at MF dear - $220 + shipping! Crazy. Saw some knock-off solenoids on eBay for $22 (free shipping) but not enough info to tell if plunger size is the right diameter/length. Can't find any cross reference info either. I checked the Woodward website which was no help. Anybody know of a cheaper fix? $220 is outrageous! Also, Rubber boot showed a little melting. Removed boot from solenoid with tiny screwdriver in an attempt to see if I can fix the solenoid but there is a printed circuit board in there with some computer chips on it- I'm not smart enough to fix.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
INOP/NON-RUNNING 2012 Jaguar XJ Passenger Car, VIN # SAJWA2GE5CMV37496 (A57453)
INOP/NON-RUNNING...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
Margaritaville 5 O' Clock Somewhere Sign (A57454)
Margaritaville 5...
