MF 1643 Intermittent Stalling/Power Loss
   / MF 1643 Intermittent Stalling/Power Loss #11
Thank you for your update. It is always interresting to see other's problems and solution, the only way to learn.....with the others experiences. See you
Update - problem returned after around 25 hours of additional run time since removing pieces of plastic from the fuel filter. Dealer's service mechanic was at my property today troubleshooting the problem. Drained the fuel tank and ran stiff wire and then air through the fuel lines. Apparently, the positioning of the fuel line from the fuel tank outlet to the fuel filter bowl can cause a problem (slight kink in fuel line). Tight area. Dealer's mechanic moved cab insulation and slightly altered fuel line position from tank to fuel filter. Fuel flow thru the line improved after line was repositioned. Not sure what causes hose to kink, maybe heat related? Only time will tell. Next step, if today's effort doesn't solve the problem, is to remove the fuel tank and replace with a new tank and new fuel lines. Dealer's mechanic said that they have had to replace the fuel tank and fuel lines on two other similar tractors to solve this intermittent stalling problem.
Hope this helps someone else down the road. I will follow-up with updates as additional hours are put on the tractor.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2019 Chevrolet Tahoe 4X4 SUV (A59231)
2019 Chevrolet...
