1510 Overheating and Fan not turning
   / 1510 Overheating and Fan not turning #1
shepeod
Virginia
Ford 1510
Ford 1510. Fan behind radiator not turning. Engine is overheating. Do I need to tighten the belt or is the fan assembly done and need replacing? Thanks!
   / 1510 Overheating and Fan not turning #2
The fan and water pump are integral and driven by the same belt, so if it isn't turning you definitely need to find out why. If the belt is snug and it still won't turn, chances are the bearings have gone out and seized it up. Normally that will take out the ceramic seal and cause it to leak as well.
Thanks for that. It’s barely turning. I can force it by hand. Is the solution to replace the water pump?
   / 1510 Overheating and Fan not turning #4
That's the usual practice for cars and trucks, with equipment you may be able to get a rebuild kit and replace the internals. A remanufactured one will usually require that you swap over the existing fan and pulley.
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
