135 Locked up on startup!
   / 135 Locked up on startup! #11
Ok Which one is the gearbox filler hole? I just tried again and as soon as you feel some resistance in the clutch i can turn the engine over. In the top 1/3rd of travel i'd say. That and the fact that i was able to roll the tractor with my trucks help tells me its not stuck in a gear. I think?
I think you locked it in gear AND sheer the sheersleeve that connect the box to the diff ?
I wouldn't be able to roll it if it was locked in gear though right? I took this pic through the hole. It appears to move between gears ok. This pic is neutral.
Yes for the left rail!
And the big gear ?
The one on the left of the pic? It moves back and forth with the lever. And i'm in Belleville, Ontario Canada.
Hey ya still :( Check this out. I found these marks / cracks with a Borescope. This is looking forward from the fill hole. This has to do with the Multipower I think?
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
