1300D Cooling system
/ 1300D Cooling system #1
Orlando
Hi,
I have a YM1300D, (155D) and a need to change the water in the cooling system, the question, is how to do it??
I have a manual, and it only says that takes 4.9 Litres !!!
What should i do first ?
Best Regards
Orlando Ferreira
/ 1300D Cooling system #2
I pull the bottom rad. hose when I change. Be careful if you do this while the system is hot
thanks
But a need to know if i only take the old water out, a fill with new one?
Do i need to make samthing else?
/ 1300D Cooling system #4
:eek: THE COOLING SYSTEM HOLDS 0.8 GALLONS. YOU SHOULD RUN A 75%WATER 25% ANTI-FREEZE MIXTURE,UNLESS YOU ARE IN A COLD WEATHER CLIMATE
SAM
Can i also clean the radiator with water before refull with the mixture?
Is it necessary to bleed the circuit? and how to do that?
Thanks
2005 Sterling Cab (A66736)
2005 Sterling Cab...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2024 CRUISER RV SHADOW CRUISER (A67714)
2024 CRUISER RV...
2011 UNKNOWN FRAC PUMP (A67714)
2011 UNKNOWN FRAC...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
OK TRUCK & TRAILER SALES PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
OK TRUCK & TRAILER...
