1300 hyd seal
/ 1300 hyd seal #1
larryreyer
1300Ford
Ford 1300, I need the seal for the piston in lift cylinder. where might I get one from ??? thanks
/ 1300 hyd seal
DSC04343.JPGDSC04341.JPG[DSC04335.JPG?.....seal maybe?,..1200 X 900. was at bottom of these pictures...?.....on messicks (website won't let me post the complete address) at ?sectionId=9393&diagramId=57923_322660...????part no. 19
/ 1300 hyd seal #4
Take the seal off the piston, get a few dimensions of the groove and the bore with calipers or micrometer. I may have that seal, pm me. Looks common.
/ 1300 hyd seal #6
Common ID and OD, there痴 a difference on the seal height though (double check that groove width of .360?. My catalogs show 4 different choices by groove width...... .260? .275? .433? .519?
Best bet is to check through your OEM tractor supplier, if no luck I can fix you up with something that works.
/ 1300 hyd seal
I found one, almost right next door. connection was through the local tractor club. Thanks, man, I'll keep your name and number, I always need tractor parts. ( never was too good at reading those mics )
/ 1300 hyd seal
OK, so`, the lip on the seal goes on the pressure side for lifting, how do I hold the pushrod inside up to get the piston to it ?H=CONFIG]662000[/ATTACH]
/ 1300 hyd seal
new seal works great, but after it warms up, all lifting quits, works for a second, pressure hits 1300, then nothing. there is noise comming from the lower part of trans, like a relief. also is alot of air bubbles in the returning oil..............thanks
/ 1300 hyd seal
i cleaned partly plugged oil lines, drained and cleaned the trans itself. Hyd worked for 1/2 an hour, then quit again . air bubbles was a leak in the rubber hose at the pump. releif noise, now not till the end the lift. BUT, will a pressure relief valve "weaken" when hot ?????
/ 1300 hyd seal
no noise,, no bubbes, but pressure still quits when hot
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2023 Kubota Z232 (A64127)
2023 Kubota Z232...
2010 Case 580N (A60462)
2010 Case 580N...
