1300 hyd seal
/ 1300 hyd seal #1
larryreyer
1300Ford
Ford 1300, I need the seal for the piston in lift cylinder. where might I get one from ??? thanks
/ 1300 hyd seal
DSC04343.JPGDSC04341.JPG[DSC04335.JPG?.....seal maybe?,..1200 X 900. was at bottom of these pictures...?.....on messicks (website won't let me post the complete address) at ?sectionId=9393&diagramId=57923_322660...????part no. 19
/ 1300 hyd seal #4
Take the seal off the piston, get a few dimensions of the groove and the bore with calipers or micrometer. I may have that seal, pm me. Looks common.
/ 1300 hyd seal #6
Common ID and OD, there痴 a difference on the seal height though (double check that groove width of .360?. My catalogs show 4 different choices by groove width...... .260? .275? .433? .519?
Best bet is to check through your OEM tractor supplier, if no luck I can fix you up with something that works.
/ 1300 hyd seal
I found one, almost right next door. connection was through the local tractor club. Thanks, man, I'll keep your name and number, I always need tractor parts. ( never was too good at reading those mics )
/ 1300 hyd seal
OK, so`, the lip on the seal goes on the pressure side for lifting, how do I hold the pushrod inside up to get the piston to it ?H=CONFIG]662000[/ATTACH]
/ 1300 hyd seal
new seal works great, but after it warms up, all lifting quits, works for a second, pressure hits 1300, then nothing. there is noise comming from the lower part of trans, like a relief. also is alot of air bubbles in the returning oil..............thanks
/ 1300 hyd seal
i cleaned partly plugged oil lines, drained and cleaned the trans itself. Hyd worked for 1/2 an hour, then quit again . air bubbles was a leak in the rubber hose at the pump. releif noise, now not till the end the lift. BUT, will a pressure relief valve "weaken" when hot ?????
/ 1300 hyd seal
no noise,, no bubbes, but pressure still quits when hot
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
UNUSED WOLVERINE TQH-26-02C 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2008 Toyota Rav4 SUV (A61569)
2008 Toyota Rav4...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
