MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,717
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Shhhhh, don't tell everyone.
Shhhhh, don't tell everyone.![]()
Best deal I found on a diverter valve
Stackable Solenoid Operated Circuit Selector Valve | Type SAE 8 SELECTOR VALVE SOL OPT SAE 8 220-934
$110.00 plus shipping
While these are a very reasonable alternative, (I have a couple in stock for less $$) if you want to make things compact plumbing wise, it is more difficult to accomplish. Of course it all depends on how you want to plumb everything, the ports on these are 1/8" closer than on the Bosch units. So you can't really use any 90s on them to start out with. Plus they are bare steel that is no where finished off as nice as the Bosch valves. Much rougher with lots of crooks and crannies.![]()
I don't suppose you have any of the bosch valves in stock? If so, how much?
You could use this valve for the grapple.
Take the PB out port from the FEL and run it through this valve .
Surplus Center - 12 VDC 10 GPM OC DA SOLENOID VALVE
Surplus Center - 1 STATION DO3 SUBPLATE OPEN CENTER
Momentary switch on joystick lever.
or this valve.
Search Results | Surplus Center
Yes, you would need two momentary pushbuttons, or a On-Off-On momentary switch.Hello JJ....would you mind explaining how these two components work with the momentary switch. I take it that you have to use two switches....one to open the grapple and the other to close it.
