12 volts and a coathanger
   / 12 volts and a coathanger #11
We need details Walkin Horse. Are you toying with our curiosity?
   / 12 volts and a coathanger #12
My guess is you're using it as an old school single or twin carbon arc torch. Probably as a single carbon arc torch, putting a carbon rod in a stinger and using the coat hanger as filler.
I can't see any other way it would work.
Edit:
Wait!!! I'm baffled again. :eek:
I just re-read the original post and he says 12v machine, and not 12v battery. :confused2:
Sorry guys. It just started out as joke at work over that other welding thread. We built a trailer mover for my tractor with a hay spear to go on it. We started makin jokes about the thread.
The weld is 7018 made with a miller inverter running on 460 volts. The guy that made the weld is a helper that I'm working with on his welding.
I guess it was funny at the time and never meant to be serious. Besides coat hanger welds don't look that good.
   / 12 volts and a coathanger #14
:laughing: I was thinking what a good coat hanger weld that was. And I've seen a few done years ago by old farmers.
You'd have to look close to see if it was weld or something done by the old rooster. :D
   / 12 volts and a coathanger #15
Lots of my welds look like that. :ashamed:
   / 12 volts and a coathanger #16
It's the thought that counts! Well done WH!
Sent from my iPad using TractorByNet
   / 12 volts and a coathanger #17
There is a way to use coathangers for arc welding, it's what people used when they were just starting to experiment. This guy uses waterglass (sodium silicate) to keep the paper on the rods, but I've heard of those old-timers just using wet paper, too. Not as pretty as WH's buddy, though...
DIY Welding Rod | MAKE
   / 12 volts and a coathanger #18
I have heard of that as well. Actually there was a thread somewhere on here about an American working in Nigeria, where the natives would steal chain link fencing to use as welding rod.
   / 12 volts and a coathanger #19
wow.. hope it wasn't galvanized...
   / 12 volts and a coathanger #20
I'm sure it was; unless they use bare or painted fence in that part of the world. If we are talking about "Zinc Flu" I doubt they knew the difference. Maybe they rubbed it down with sand to remove it? Can't remember who posted it, but I know it was on TBN... the OP travel worked for oil companies around the world. I don't even remember what the thread was about, but that came up.
Edit: perhaps it was "strangest thing you've had stolen"
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A51219)
2016 INTERNATIONAL...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
Caterpillar Front Glass (A50854)
Caterpillar Front...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
