12 volt pump to lift farm implements question
   / 12 volt pump to lift farm implements question #21
Yes, I'll need to check on the bale bed fluid before going forward with that idea. Good point, also made by Aaron. I know the bed installer mentioned using one type over the other, but can't remember right now which he used.
This seemed to be the best thread to take off on; if this board prefers a new thread in such cases please advise.
   / 12 volt pump to lift farm implements question #22
...there appears to be a second hole on the rear hyd mount below/behind the knotch. I'd suspect that will line up with another hole for the transport pin...
Farm Boy - I stand corrected. I took a closer look and found a hole in the chisel frame that lines up with the second hole you mentioned, and a similar setup on the disc. I just need to figure out how to get those holes aligned w/o hydraulic power.
I'm considering taking my small backhoe out there (it will fit on my 16' utility trailer). I believe I can lift one end of the chisel and disc enough to drop the wheels so the transport holes will align. I can also just lift the plow with the FEL and set it on the trailer. May take a few more trips to get it all back home, but doable.
   / 12 volt pump to lift farm implements question #23
Do you have a Hi-Lift jack and something to block the frame with?
A shop crane/engine hoist in the pickup bed, chained to the gooseneck hitch is what I have used for similar situations.
You might be able to load them on the trailer, then hook on and bring them home.
   / 12 volt pump to lift farm implements question #24
Gin Poles and a big come-along would also work to load them on the trailer.29777d558d96481.jpg GinPoleBox.jpg 1957.International.R-200.detail.rigging.jpg
   / 12 volt pump to lift farm implements question #25
I have been in this predicament before, I always thought a portable pump of some sort would be handy to have around. I was thinking something like this, 12 Volt DC Hydraulic Pump Double Acting Dump Trailer | eBay, could be used with a 12v booster pack or cables off the tow vehicle. Recently lost the hydraulics in my mowing tractor, try to lift the cutter head on a mower conditioner without hydraulics, a hi-lift aint gonna do it, been there done that.
Did this project ever work out HCJtractor, curious how you made out.
   / 12 volt pump to lift farm implements question #26
That's essentially the elec/hyd unit that is powering my bale bed, hence my initial inquiry. As has been stated, since the thing is powering two double-acting cylinders under the bed, it should be perfectly capable of powering other cylinders, assuming the fluids between the two systems are compatible.
2017 Chevrolet Sonic Sedan (A55758)
2017 Chevrolet...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2009 Honda Pilot AWD SUV (A55758)
2009 Honda Pilot...
black Max power washer (A55787)
black Max power...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
