12" backhoe bucket with pics
/ 12" backhoe bucket with pics #1
spo307
Levittown & Long Eddy NY
kubota L4400
finished welding the bucket, 5/8" cutting edge bottom 1/2" mounting plates, 1/4" sides, 3/16 back plates, now for the hard part of cutting the 1/2" mounting plates and getting dom tubing for the bushings
/ 12" backhoe bucket with pics #6
Nice job.:thumbsup:
I was curious though if the sides are parallel, or are tapered?
slightly tapered, probably should have been more, but it will work. i hope
/ 12" backhoe bucket with pics #8
nice job, I'm thinking about making some sort of clay bucket this year. The prices on buckets are crazy.
/ 12" backhoe bucket with pics #9
Great job!:thumbsup:
Yup, the bucket prices are too high.
/ 12" backhoe bucket with pics #10
Nice. Show us the unit in action when you are done please.
/ 12" backhoe bucket with pics #12
Great looking bucket. Is there anyway that you could dimension and post the measurements for yor side plates? Thanks...
I think I am in need of a 1 1/4 reamer to clean up the holes, also rear pin must have a slight bend, I will hold off finishing it till i get my kubota pins
/ 12" backhoe bucket with pics #15
decided to weld it up without kubota pins, after an hour of sanding the pins with drywall sanding screen and 400 grit paper, ripped a 1x6 and clamped as a jig. made small even stitch welds as to not bind the pins, i would weld one side and pins would lock up, then weld opposite side to regain movement, also decided to add a band around the back to the bottom cutting edge 1/4 x 1 1/2, weld the upper half heat at the bend with a torch bend over and use a lump hammer to fit tight, weld, repeat. marked the bucket with an s. in the end pins move fine, primmed painted. just need teeth to come in
/ 12" backhoe bucket with pics #19
Looks very good!!! How many $$$ in it?
2020 KENWORTH T270 SERVICE TRUCK (A59823)
2020 KENWORTH T270...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2019 KENWORTH DAY CAB (A59905)
2019 KENWORTH DAY...
2013 Ford F-150 Pickup Truck (A59230)
2013 Ford F-150...
