12" backhoe bucket with pics
   / 12" backhoe bucket with pics #1
spo307
Levittown & Long Eddy NY
kubota L4400
finished welding the bucket, 5/8" cutting edge bottom 1/2" mounting plates, 1/4" sides, 3/16 back plates, now for the hard part of cutting the 1/2" mounting plates and getting dom tubing for the bushings
   / 12" backhoe bucket with pics #3
sure looks solid enough! Nice fab skills.
What is the bucket going on?
BH90 kubota L4400, I have an 18" already, wanted a smaller bucket for more break out force, then they told me $650, then my wheels started turning
   / 12" backhoe bucket with pics #6
Nice job.:thumbsup:
I was curious though if the sides are parallel, or are tapered?
slightly tapered, probably should have been more, but it will work. i hope
   / 12" backhoe bucket with pics #8
nice job, I'm thinking about making some sort of clay bucket this year. The prices on buckets are crazy.
   / 12" backhoe bucket with pics #9
Great job!:thumbsup:
Yup, the bucket prices are too high.
   / 12" backhoe bucket with pics #10
Nice. Show us the unit in action when you are done please.
   / 12" backhoe bucket with pics #12
Great looking bucket. Is there anyway that you could dimension and post the measurements for yor side plates? Thanks...
I think I am in need of a 1 1/4 reamer to clean up the holes, also rear pin must have a slight bend, I will hold off finishing it till i get my kubota pins
   / 12" backhoe bucket with pics #15
decided to weld it up without kubota pins, after an hour of sanding the pins with drywall sanding screen and 400 grit paper, ripped a 1x6 and clamped as a jig. made small even stitch welds as to not bind the pins, i would weld one side and pins would lock up, then weld opposite side to regain movement, also decided to add a band around the back to the bottom cutting edge 1/4 x 1 1/2, weld the upper half heat at the bend with a torch bend over and use a lump hammer to fit tight, weld, repeat. marked the bucket with an s. in the end pins move fine, primmed painted. just need teeth to come in
   / 12" backhoe bucket with pics #19
Looks very good!!! How many $$$ in it?
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2010 BOBCAT TOOLCAT 5610 UTILITY WORK MACHINE (A59823)
2010 BOBCAT...
iDrive TDS-2010H...
2003 Big Tex 10PI...
