12" backhoe bucket with pics
   / 12" backhoe bucket with pics #1
spo307
Levittown & Long Eddy NY
kubota L4400
finished welding the bucket, 5/8" cutting edge bottom 1/2" mounting plates, 1/4" sides, 3/16 back plates, now for the hard part of cutting the 1/2" mounting plates and getting dom tubing for the bushings
   / 12" backhoe bucket with pics #3
sure looks solid enough! Nice fab skills.
What is the bucket going on?
BH90 kubota L4400, I have an 18" already, wanted a smaller bucket for more break out force, then they told me $650, then my wheels started turning
   / 12" backhoe bucket with pics #6
Nice job.:thumbsup:
I was curious though if the sides are parallel, or are tapered?
slightly tapered, probably should have been more, but it will work. i hope
   / 12" backhoe bucket with pics #8
nice job, I'm thinking about making some sort of clay bucket this year. The prices on buckets are crazy.
   / 12" backhoe bucket with pics #9
Great job!:thumbsup:
Yup, the bucket prices are too high.
   / 12" backhoe bucket with pics #10
Nice. Show us the unit in action when you are done please.
   / 12" backhoe bucket with pics #12
Great looking bucket. Is there anyway that you could dimension and post the measurements for yor side plates? Thanks...
I think I am in need of a 1 1/4 reamer to clean up the holes, also rear pin must have a slight bend, I will hold off finishing it till i get my kubota pins
   / 12" backhoe bucket with pics #15
decided to weld it up without kubota pins, after an hour of sanding the pins with drywall sanding screen and 400 grit paper, ripped a 1x6 and clamped as a jig. made small even stitch welds as to not bind the pins, i would weld one side and pins would lock up, then weld opposite side to regain movement, also decided to add a band around the back to the bottom cutting edge 1/4 x 1 1/2, weld the upper half heat at the bend with a torch bend over and use a lump hammer to fit tight, weld, repeat. marked the bucket with an s. in the end pins move fine, primmed painted. just need teeth to come in
   / 12" backhoe bucket with pics #19
Looks very good!!! How many $$$ in it?
14' 10" METAL STORAGE RACK (A60432)
14' 10" METAL...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
GIYI BF47-47" (2) PRONG BALE FORK (A60430)
GIYI BF47-47" (2)...
UNUSED FUTURE FTH50-(50)SHEETS OFGALVALUME (A60432)
UNUSED FUTURE...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Pemberton 6ft Loader Forks and Frame (A59228)
Pemberton 6ft...
