Tires 112 tire change question
/ 112 tire change question #1
selkie
North of Pittsburgh, PA
How do I get the little cap off the center of the front wheel on my 1969 JD 112? I need to change the tire, but I can't get that cap off! Tried a crowbar (with and without a hammer), penetrating oil, etc... even tried a puller but couldn't get the cap off far enough to get the puller on it.
What am I doing wrong? /forums/images/graemlins/confused.gif
Thanks in advance!
/ 112 tire change question #2
Try a large wide blade screwdriver between the cap and wheel hub. Just tap the screwdriver in the groove and give it a twist, the cap should pop right off. There is a special tool for this that looks like a large pair of pliers with inward facing jaws, but a screwdriver should work fine. If it looks rusty apply a little WD40 or PB Blaster and let it soak in for awhile. You can do it.
Ken /forums/images/graemlins/smile.gif
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
