Chains 110 TLB tire chains
/ 110 TLB tire chains #1
ME83
Western MA
JD 110 TLB
I know there are many months before Winter comes back around, but I like to be well prepared. Does anyone one here run tire chains on the rear tires of the 110 TLB? We tend to get a mix in winter storms where some will have some icing, and chains make a huge difference in winter. My concern is there is some room between the tires and fenders, but not a whole lot. With the fenders being plastic I don't think they will stand up to a tire chain hitting them for very long. I would prefer not to have to put wheel spacers on, but if that is my only option then I would.
/ 110 TLB tire chains #3
If you use chains, just install some spring tensioners. They will pull all the slack out of them, so they should not hit the fenders unless you don't tighten them up.
I put them on my 2520 with R4's, and there is not much clearance, but they don't even move on the tires, so they'll never hit my fenders. I don't drive it super fast either, because I know the centrifugal force will make them WANT to go twords the fenders. I have driven it wide open in high range and they still never moved, but its just not brillant.
They are plastic fenders, it wouldn't take much for a chain to mess them up in a hurry.
Thank you for the link to AKFish's post, I will most likely end up getting the Bobcat spacers. I figured that would be my only option, the rims didn't look to be reversable.
