murphy1244
Super Star Member
- Joined
- Nov 25, 2011
- Messages
- 19,527
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
his is bending the arm.
Whoa... really??
I thought that maybe I'd "overreacted" and concluded that the issue was really a matter of misplaced "concern". So, I went back and carefully looked over the OP's initial photos. Nah, I didn't overreact; the problem is really misplaced concern!
You might wanna go back and revisit those pictures as well.
Look at the front plate of the dipper arm. Please note the concave surface and the inside gap between the dipper and the contact/wear plate. During the final welding and construction of the dipper arm, the surface of the arm developed a "normal" concave.
I would bet "dollars to donuts" that virtually every boom arm and dipper arm you'd care to inspect - irregardless of manufacturer - has some distortion. Every sheet of flat steel or plate steel that I've ever looked at has a measure of warpage. Before... before it's ever been welded! A perfectly flat surface or perfectly square dimension is a fantasy.
I'd like to see photos of straight edge measurements taken along the face of the boom arm and dipperstick ALL THE WAY to the thumb - beginning at the bottom of the boom arm.
AKfish
in this photo you can see that someone closed the arm with the thumb opened and did some damage
View attachment 306093 View attachment 306094 View attachment 306095View attachment 306096
Was this done with an OEM JD thumb like showed in the first post on this thread?
To me it looks more like marks made by the bucket teeth.
maybe your right, i just assumed that it was from the thumb
Ok... here's when I'll have to admit to making a dumb @ss move with my 110 backhoe!'Cause I've got a dent along the edge of my boom arm - just like that!!!
If you leave the stabilizers in the up position and swing the hoe from side to side.... well, the backhoe is NOT designed to do that! And those darn stabilizer feet will absolutely crimp and roll it over; that 1/2" (might be 5/8") thick plate steel! Aaarrggh!
I only did it on one side, though... that was enough. 'Course, if you were in a full-blown swing motion - it would/is very hard to stop that motion with those legs up - the whole back end of the tractor is swaying! And you could crimp both edges.
AKfish
OK I can see that happening.
My DA move was just the opposite. I had the hoe swung to the side and under the stress of working my way out of being stuck I for some unknown reason raised the stabilizer on that same side and hit the hydraulic fitting that goes into a steel line and cracked it where the fitting was attached to the steel line. After having to fix that fine mess I expect I will never be tired enough to forget and do that again.
After that late one evening I was so proud of myself. I was moving the dirt from the same place where I got stuck cleaning out a ditch and messed up the hydraulic fitting with the stabilizer. I was going to have to use the truck lights to make one more load and after telling the kids we were going to make one more trip I just shut off the truck and got out. They wanted to know what was wrong. I told them we were through for the day and they like to have freaked out.
A feeling just came over me that I was pushing too hard being so tired and hungry and that adding in the low lighting condition just made the risk higher than I wanted to accept for an accident to happen. It was the same conditions that messed up the hoe with the stabilizer about a month earlier because I waited for the mud to dry before moving it.
2
3
4
5
