110 TLB Grapple choice
   / 110 TLB Grapple choice #11
Matt,
I have a Worksite pro 66" rock bucket with 3" spacings, while it helps it does hold too much dirt for my liking. As far as weight I would not want a grapple to weigh over 800 lbs, less would be better imo. The second grapple you linked too seems about right imo.
Keep in mind that you don't necessarily need a grapple wide enough to cover your wheel width. That will help on weight. You also don't need a grapple that will stand up to a high horsepower CTL. I'd look at the heavier tractor type or light weight skid steer units.
I'm leaning towards a 65" grapple at this point. Here's the other unit I'm interested in:NOTCH Manufacturing Inc.
It's in the 600lbs range.
Matt
   / 110 TLB Grapple choice #13
I agree, you don't need a 72'' wide grapple. That's what I have. If I had to do it all over, I would buy the narrowest grapple that will fit. (I should have listen to the guys on TBN ) I bought the grapple from MIE
Error
   / 110 TLB Grapple choice #14
I have the same one as Doc but 66".
   / 110 TLB Grapple choice #15
I should have mentioned that I previously had a swept bottom single lid made my Millonzi. I usually grab several logs at a time so not too concerned about it rolling around. I also will be used for rocks, which the root rake type aren't the best at. I'm mostly concerned about the weight. I believe my tractor is rated to around 2600lbs at the pins, is a 900lbs grapple gonna make me wish for a lighter unit?
Why not use the Millonzi? I use one with a 2760lb lift Kioti DK40. Works fine. At about 300lbs it leaves you with lots of net lift capacity.
   / 110 TLB Grapple choice #16
View attachment 422202 View attachment 422203 View attachment 422204
Error
Doc, that's a nice grapple, what's the weight on it? I like the rear screen and it looks to be a good compromise. How do you like it?
As far as the width I agree to an extent but it really depends on what you're doing. If your picking up brush, the larger width is good but for the majority of my uses a narrow unit will work.
The Millonzi went with the sale of my 3320, bare in mind I've had a grapple for year so I'm very familiar on the pro's an con's. I'm just torn on this purchase because the 110 is a bit more powerful and I want a robust grapple that's not too heavy. It seems to be a very fine line. No matte what I buy I'll likely always wonder about another style. There's just too much good stuff out there.
Matt
I was even more convinced I need a grapple ASAP this weekend. Loaded up two trailer loads of Oak like this.IMG_1041.jpg
The 4in1 is ok but it's no where near as capable as a dedicated grapple. I also used the forks a bit and a lot of hand loading ensued which ate up valuable time. Since the stump had an appointment with the Morbark, what an awesome machine and the operatorwas fantastic.
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
Pallet of Gas Powered Misc Engines (A54865)
Pallet of Gas...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
2011 Ford F450 Diesel with Just 156638 Miles (A55302)
2011 Ford F450...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55302)
2012 NEW HOLLAND...
2015 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52706)
2015 CATERPILLAR...
