110 TLB Grapple choice
   / 110 TLB Grapple choice #1
GreatWhitehunter
Eastern CT
JD 110 TLB
I'm looking for a grapple for my 110 TLB, I've had my eye on the Notch brand grapples but haven't been able to find much owner feedback for them.
I've also been looking at the Faver grapples which seem to have solid reviews, I happened across a Steinsammler on Ebay which looks awesome but looks a bit heavy at 960lbs for the 65" model.
I've also looked hard at the EA wicked grapples and their CA cousins but I like the flat bottom design VS the curved up fronts on the EA & CA.
My 110 has pretty good lift capacity for the frame size but don't want to be disappointed by the weight. I know there's a thousand grapple threads on TBN but I'll test the waters anyways. I'll be clearing 5 wooded acres with this grapple over the next few years so it needs to last. Most of the materials will logs and tops (mostly smaller red oaks 8-10").
I'm not to concerned of the cost as this a long term investment.
Matt
   / 110 TLB Grapple choice #2
Check on the Root Grapple by Loflin: Loflin Fabrication
It is the smaller version of the Monster Grapple that I have.
   / 110 TLB Grapple choice #4
For your stated main use being logs and tops I would stay away from the flat bottomed grapple that you linked to. Look at the dimensions of the above grapple and the logs you are wanting to carry will just flop around in the jaws. I've owned both styles and IMHO you would be better served getting a grapple the will hold your logs firmly.
It's harder to pick up single logs with the flat bottom grapple and harder to place on a trailer etc when they roll around in the jaws. Look at a 60-66" of this style: RBG
I should have mentioned that I previously had a swept bottom single lid made my Millonzi. I usually grab several logs at a time so not too concerned about it rolling around. It also will be used for rocks, which the root rake type aren't the best at. I'm mostly concerned about the weight. I believe my tractor is rated to around 2600lbs at the pins, is a 900lbs grapple gonna make me wish for a lighter unit?
   / 110 TLB Grapple choice #7
Matt,
I have to agree with the RBG would be the easiest to use picking up logs. The grapple Faxman shows would be preferred over the Steiner you linked to. Too many tines on the Steiner imo, means it will hold too much dirt. If you need to scoop up small debris you can swap back to your standard bucket. I would think the small debris can be worked back into the soil, you want to get out only the larger pieces to put on a burn pile or haul away.
Just my thoughts after cleaning up a lot of messes.
Matt,
As a 110 owner, what do you think is idea on weight? I actually partial to the tine spacing on the Stiensemmler, as it'll double as a rock bucket but allow the small stuff through. The faver is another favorite as it closes tight and has the flat tines. 72" Faver Skid Steer Brush Root Log Grapple Rake Loader Bucket Attachment Bobcat | eBay
   / 110 TLB Grapple choice #10
Keep in mind that you don't necessarily need a grapple wide enough to cover your wheel width. That will help on weight. You also don't need a grapple that will stand up to a high horsepower CTL. I'd look at the heavier tractor type or light weight skid steer units.
ALLISON TRANSMISSION (A55745)
ALLISON...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
