1050 will not start
/ 1050 will not start #1
Rehoboth, MA
JD 1050
Went to start my 1050 yesterday. It started for a minute, and was running very rough, and stalled.
Now, she'll crank, puff smoke while cranking, but will not start.
Thoughts on things to try? Already put in fresh fuel in case there was any contamination.
/ 1050 will not start #2
Fuel filter? maybe water crept in...
you say "fresh fuel", meaning you drained the old fuel out or just added more?
Using any additive for the diesel fuel ?
/ 1050 will not start #3
I'll suggest to check for good fuel flow from fuel tank to fuel inj pump. Check to determine if fuel tank is venting.
/ 1050 will not start #4
Ice in the secondary filter? Pre-heater working ? Can you try to push start it ?
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
iDrive TDS-2010H...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
