Snow 1026R Snowblade
/ 1026R Snowblade #1
cottermac
John Deere 1026R
I just got my new1026R the other day and was wondering if anybody had one with a 54 inch snow blade. I'm trying to find some pictures of the front adapter for the QH. The dealer told me the hitch from my 445 won't work on this tractor but I think I can fabricate something to make it work. So if you could post a couple of picture I would be greatly appreciative.
/ 1026R Snowblade #2
Go to jdparts and look up the model no. of the blade. That might give you the info you want.
You can likely use the quick hitch you have, and see pretty quick why/how it doesn't mate up to your new 1026r. As well as see what needs to be altered to match the 54 blade (which likely didn't change much and the 445 hitch mates up to it (or do you already have the 54" blade? ).
/ 1026R Snowblade
I did try JDparts but was unable to find the break down of the 1026R hitch. The dealer was also unable to find the break down for the hitch. But I did find one picture of a tractor with a snow blade from which I'm pretty sure I just need a an adapter to make it work.
/ 1026R Snowblade #4
Do you have the 445 hitch and the blade that you want to put on the 1026?
/ 1026R Snowblade
Yes I do, Sorry I meant to put that in my first reply.
/ 1026R Snowblade #6
Then you are first in line to see just how it doesn't fit. At least you know that the hitch you have fits the blade you have. Only need to fit the hitch to the new tractor.
Let us know....too small, too big, ??
I would only guess that the front tires on the 1026 are larger than the 445, so the hitch will need to be lowered a bit to get the plow to push from lower down.
/ 1026R Snowblade
I will update this when I find the solution, and the tire sizes are the same from the 445 to 1026r.
/ 1026R Snowblade #8
I've posted pics of the quick hitch support items on GTT and MTF, but not here. I went 29 days without my 445 quick hitch before my new R with quick hitch arrived, so my recollection is a little hazey. It seemed to me that the 445 hitch is smaller in every direction than the R hitch. I do agree with the others though, you should be the one to show us the way, with lots of pics of course.
/ 1026R Snowblade
So its taken awhile to get to this point but, I finally found the answer to my question. My blade from my 445 will fit my 1026R, all I need is the adapter bracket and hose extensions. I have the bracket on order ($62 +tax) so hopefully when I get it all together I can post some pics and part numbers to help everybody out.
/ 1026R Snowblade #10
I'm getting the new adapter brackets plus the frnt hyd lift w/angle. I was told blade would work nothing else. I'm keeping my blade because I have a cutting edge off a D9 dozer..not planning on bending blade or wearing out the cutting edge.
I haven't seen these new parts coming over the next couple of weeks.
/ 1026R Snowblade #11
Sorry for resurrecting an older thread, but can you (or anyone else) give me any information about this adapter bracket? I have a 425 with 54" blade/quickhitch and would be interested in knowing what it would take to make it work on a 1025R.
/ 1026R Snowblade #12
My brother in law has one on his 1023. I believe the blade is the same 54D as before. The front hitch bracket looks also to be the same. The adapter you are referring too is also needed with the 1023 to install the front blade. I will post pics when I'm over there later today.
/ 1026R Snowblade #13
I found the diagram on jdparts with no problem. here it is...
I don't know about the parts in common but seems to me if all other parts are the same you can just replace the part #7 ?? AM132310
really wishing I had negotiated a snowblower with my 2210 when I bought it back in the spring of '04. I don't have a front hitch and never saw one up close except in photos.
/ 1026R Snowblade #14
Sorry I didn't make over to my brother in laws house to get pics for u. He had the flu and I wanted to stay clear. He's over it now. I'll go over there tomorrow after work and get pictures of the blade and mounting hardware for you. Again sorry for the delay.
/ 1026R Snowblade #15
As promised here are the pics.1023blade 001.jpg1023blade 002.jpg1023blade 003.jpg1023blade 004.jpg1023blade 005.jpg1023blade 006.jpg
/ 1026R Snowblade #17
I'd had the idea that if I had a front hitch I'd make a front carrier for my 62c deck for mowing out front, which I believe would give great results and make blade maintenance easier. Not sure how well the hitch would hold up to the pounding long term.?
(2) UNUSED 15-19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15-19.5...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
2001 CHAPPARAL B/STOCK TRAILER (A64280)
2001 CHAPPARAL...
Fuel Tank (A64119)
Fuel Tank (A64119)
