1026r mower question
/ 1026r mower question #21
Maybe english is not his first language -- that can often make someone come across the wrong way. I agree, pics would help clear up things.
/ 1026r mower question #22
Then dealer drop off tractor . The mower did not auto connect. Please do not reply if you do not own 1023 or 1026 . It's not set up or user. The face it . Over price junk
Yes by all means keep repeating the same mantra and you are bound to get some helpful suggestions. That reminds me... been a while since I watched Forrest Gump.
/ 1026r mower question #23
I recently adjusted my 60d deck on my 1026r. I then noticed it didn't want to connect after the adjustment. I had to adjust the stop bolt on the mid pto so it would connect again. Maybe this will help.
/ 1026r mower question #24
From everything I can tell, this IS a set-up issue. If the OP has an AutoConnect mower with Independent Lift, there are still two latches that need to be closed after driving over the deck. If everything is not set-up correctly those two latches (or sometimes just one of them) cannot be closed / latched. The reason I wanted your S/N is so that I could contact the Area Service Manager on your behalf as this seems to be a DEALER issue NOT a DEERE issue. Again - I am basing that statement on what I can tell from the posts.
A - Your dealer should have asked you how you were planning on using the equipment and sold you the correct set-up - even if they had to wait to get a mechanical lift system. You have 3 main choices: 54D or 60D deck, Mechanical or Independent Lift and Manual or AutoConnect PTO. Any of these options will work with any of the others. Want 54D with AutoConnect but Mechanical Lift? Not a problem. 60D with Independent Lift and Manual? Again, no problem. I am thinking that the dealer did not ask these questions and sold the OP what they had available or what was close to coming in.
B - Incorrect installation / adjustment will cause the problems the OP is experiencing. In a case like this the Dealer should NOT charge for pick-up and delivery or at home service. If it was a regular warranty issue then pick-up/at home is not included in the warranty although many dealers include it as part of thier sales process. New paint will not cause the issues I believe he is having.
HI bleengreen.Yes you are right.when drive over mower it will not latch.You need to get on your hands and knees and pull and fight to get it latched on both side on deck.Some times need to go back and forth the three to four times on both sides of deck to latch it.Also when you go to take off deck its very hard to unlatch.So hard you need to shake deck and pull all you strength to get it to unlatch.When dealer drop it off he told me 54 in decks where having latching problem but would get better with time.I sould of told him but it back on dealer and give me money back.As you know if it will not latch from day one it might never work.I did get 54d with Independent Lift and AutoConnect PTO.I was never told you needed to hook up hose when wanted mower to go up and down.If so I would of never got Independent Lift.bleengreen can you tell me the parts and how much the are and how to change it to Mechanical lift.
thanks for your help
/ 1026r mower question #26
s219 I suspect your right. If Mike is from Fort kent Maine there is a good chance he speaks French.
Bonjour Mike et bienvenue à TractorByNet
/ 1026r mower question #27
The only reason you are having a latching problem is because your dealer did not set-up the machine properly. They should have never delivered it without it working properly - and to blame it on paint and to say 'it will get better with time" is complete and utter horses%*t.
Call your dealer immediately and ask to speak to the owner. Explain that you are very unhappy with the machine and that you should not have to pay for transportation as this is not a warranty issue but a dealer setup issue. If they continue to tell you that you must pay for transportation I would ask to have the Deere TSM contact you directly.
In regards to Independent vs. Mechanical Lift simply state that the Independent Lift was not explained to you and that you were given no choice as to the Mechanical Lift. I believe they should change it to Mechanical Lift at no charge to you - especially with the issues you are having. The Mechanical Lift is lesser priced to begin with and they will then have the Independent Lift to install on another machine.
/ 1026r mower question #28
just one honest question. He mentions that the video does not show all the steps? is that true? I've always wondered if that was the case, seems you should need raise the scalp wheels and stuff like you do on most other drive overs.
/ 1026r mower question #29
There are 4 quick locks on the 4 gauge wheels. One "flick" of your hand releases the wheel - it should take all of 1 minute to walk around the machine and release the gauge wheels. This allows the deck to go all the way down to the ground as the gauge wheels are no longer locked. Get on the machine, lower the deck all the way. Choose low gear (and possibly 4WD depending on surface) and back off the mower. That is it.
/ 1026r mower question #30
I believe you need to follow the steps outlined here: 1 series mower setup and adjustment
This is the process your DEALER should have followed. It seems as though many DEALERS are not going through the proper setup. It is the DEALERS fault. DEERE has outlined everything the DEALERS should do in your manual, but the DEALER SHOULD pick up your tractor PROPERLY set it up as they were SUPPOSED TO in the first place! This is NOT a DEERE issue, but a DEALER issue. Many people are having the same issue with their DEALER as you are, most DEALERS have taken care of their customers and got their tractor setup properly and back to them FREE as they were supposed to do originally!
/ 1026r mower question #31
...or brought them out correctly the first time... after testing at the dealership to ensure product quality before delivery.
/ 1026r mower question #32
My point exactly. These dealers that are giving the 1 series such a bad rap need to get their act together! This isn't a build or engineering issue, it's a lack of attention to detail by the dealer and it's a shame that those dealers are giving this good product a bad rap. It's had some other pitfalls that aren't dealer involved, but the MMM issue is by far the most prominent, and something that should never occur.
again going to tell step to remove and install mower
install mower.If mower is in garage Drop all four wheel and to roll it on lawn for install.
Go to front of mower and make sure pull up on front round rods.next unlock all four wheels.need to turn knob on tractor to install .If you have Independent Lift you need to hook up hose on tractor.side tractor in 4x4 and drive over deck.If it all lock in place that great but allot of them are not so when you lift mower it fall off tractor.the must back up and tray again.get off tractor to lock it in .If you are like me its not and need to fight and pull and tug to lock it in.IF you lock it in after fighting for it 15 min you can lift mower and need to adjust all four wheel to hight you want cut uoir grass.
Remove unlock all four wheels,unlock mower very hard to unlock.drive over deck .Independent Lift unhook hose.Drop all four wheels and store mower.
want to remove Independent Lift from tractor.Really hate it.I called dealer four to five times to get answer on price and parts needed still waiting.
/ 1026r mower question #35
I wish you were closer. I would trade you my mechanical lift for your independent lift.
/ 1026r mower question #36
I have not seen anyone mention that instructions mention to have pto selection set for rear pto. This should allow the front pto free to move when trying to connect the mower.
/ 1026r mower question #37
I overlooked that also & my dealer did not tell me to do it.
None of the online videos that I have seen mention that either.
hi all
I did steps that martain said to do.all the step set up mower. Like dealer would to make it mow nice.It did not do anything to make it latch after drive over deck or unlatch easy.I thing this is JOHN DEERE problem.I called my dealer and he didn't know where to turn.Not very happy with this.This is my first and very last johndeere.
/ 1026r mower question #39
This confirms my suspicions all along. It's a user malfunction! Good luck.
Hey jdphan why would you say that. When dealer drop it off at my house it would not latch after install deck. So saying john deere trained guy is manlfunction.You are wrong. How about tractor it self is malfunction.You drive over deck it should latch itself.If it don't its john deere problem.
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2006 International 4200 2,000 Gallon Water Truck (A61573)
2006 International...
