10 foot offset disk
/ 10 foot offset disk #1
cooperman
Wilton,Ca.
Cat D4, Ford 6610, JD 990 and Agco GT 75
Before going to look at a Ford 10' offset disk I would like an opinion if my 83 hp 4wd tractor is enough?
/ 10 foot offset disk #2
With it being 4WD I think you will be o.k but I guarantee you it will be all it wants. Do you know what size the disc blades are?
/ 10 foot offset disk #3
It should be fine. My 70 HP tractor pulls an 8' offset set wide open quite easily. I used to have a L3650 (36 HP) that would pull it in 4WD and low range.
Besides, you can always gear down and take your time.
/ 10 foot offset disk #4
The width of the Disc Harrow does not relate well to the draft force generated in pulling.
The important metrics are PAN DIAMETER, (A=πr2), where the weight is, and the NUMBER of pans.
Third is pan thickness, a spec hard to come by. However, proportionally, thickness does not vary like pan diameter.
/ 10 foot offset disk #5
Depends on the weight of the disk and size of the blades and a photo would be great. You probably could pull it.
/ 10 foot offset disk #6
Not all offsets are created equal. Some are super heavy and aggresive and designed as primary tillage tools. I have thought of a 10-12' offset but wonder if my 135 HP 4440 with duals will pull it. Some it would I am sure but some it wouldn't.
/ 10 foot offset disk #7
Here's one at 992lbs per disk. Can be had in 9'-12' working widths. Something tells me that your tractor isn't quite enough.
/ 10 foot offset disk #8
I'm not real smart. Is a pan the same as a disc?
I bought the disk, good bad or ugly. It has 24" stubbles on the front and 24" smooth on the rear. I have used a 9' offset drag with 20s all around and it pulled it like going through butter in 4x4. With the gauge wheels isn't up to the operator to set depth so you don't over work the tractor?
/ 10 foot offset disk #10
I think you should be able to pull it with wheels full up with 83 HP (is this drawbar or engine?) but design of the disk and soil type is critical to how much power it takes. I remember John Deere made an offset disk back in the 60-70s that was hard as heck to pull due to the shape of the disc, they were radically cupped but then transitioned to flat at about a 6-8" radius at the axle. They seemed to require 20+ HP more to pull them compared to a concentrically shaped disc but they would turn over the dirt at super slow speed whereas as a normally cupped blade had to have twice the speed to turn the soil over.
/ 10 foot offset disk #11
YEP, that is what the carry wheels are for, to set the depth of cut to some extent. You can also load up the wheels with ballast fluid to add weight to the disk if you need it. Some disk with 4 each 11:00x16 tires would put a lot of weight on the disk when fully retracted. You can also get clamp on spacers to put on the hydraulic lift cylinder to set the depth so it is constant without guessing at it each time.
/ 10 foot offset disk #12
It's usually not the first pass across the field that really strains the tractor as a lot of times you are not getting as much penetration in hard packed soil, but on the second pass your tractor is in loose soil and the offset harrow is now really getting penetration and it lets you know that it's back there. I usually use an Athens 8' or 9' offset I can't remember the width for sure with 24" disc blades, I use it to get my winter rhye pasture ready after summer millet and it will be hard packed from the cows grazing on it all summer, so the ground is to either turn with a plow or bust open with an offset disc and then finished up by running over it with a leveling harrow and a good drag.
/ 10 foot offset disk #13
I think 50HP would pull it okay..............
.............................................As long as the transport wheels where all the way down:laughing:
/ 10 foot offset disk #14
I'm not so sure that it could stop it though, at about 20,000lbs that could be a run away. :eek: I suppose if you had lift control you could drop the disks. ;)
Keota MFG Bale Mover (A65640)
Keota MFG Bale...
2022 EZ-GO ELITE...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
10.5' Telescoping Ladder (A66408)
10.5' Telescoping...
2024 JOHN DEERE...
Mini Universal Tree Spade (A65640)
Mini Universal...
