1 Wire Alternator
/ 1 Wire Alternator #1
PaulWinLA
Anacoco, Louisiana
Mitsubishi MT 225 FD
Anyone replaced the alternator on a 1976 Ford 3600 tractor with a 1 or 3 wire alternator? If so, what was it and where did it come from. As a last resort, can anyone tell me how to wire the normal alternator as mine has loose wires hanging everywhere and the alternator is dead.
/ 1 Wire Alternator #2
Re: 1 wire alternator
bring your alternator to an auto parts store, and match up the mountings. you can install a much larger alternator amps wise that way.. both 1 wire and 3 wire have a built in regulator, which is good.. you can take a look here. https://www.tractorbynet.com/forums/parts-repairs/133835-my-1-wire-alternator-experience.html you are much better off using a 3 wire alternator, since the feild can be energized by the battery, instead of needing to be spun at a high RPM to get the field excited!.. also, you can have the charge light working!.. you can use a 10si or 12si alternator..
/ 1 Wire Alternator #3
Here is a web site with considerable information on electrical and wiring for automotive uses it will cross over for tractors quite well.
It will also inform you of the correct wiring for various alternators and the issues with one wire alternators.
Good Luck
MadElectrical.com - Electrical Tech
/ 1 Wire Alternator #4
Good Luck
Good site, came in here to post it.
/ 1 Wire Alternator #5
I would suggest if your charge light is working that you strongly consider a 3 wire Delco 10SI conversion. A functional charge indicator light is not a bad thing, and as suggested, the alternator gets an immediate and reliable excitation.
/ 1 Wire Alternator
Thanks, a friend gave me an alternator 10SI, but it will not fit on my tractor, so I am in the process of going back with the type that came installed on the tractor.
/ 1 Wire Alternator
I find there are too many issues with that, I would lose my tachometer for one and it would be hard to get the right pulley and correctly sized holes for the mounting bolts. Thanks anyway.
/ 1 Wire Alternator #10
Many areas have local shop that can repair alternators and starters.
Sometimes a goggle local search will find them.
/ 1 Wire Alternator
ha ha, I live in the sticks, I prefer a new alternator, as I will be selling the tractor once it is repaired.
Thanks
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
Can Am Defender (A63689)
Can Am Defender...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
