1 Set Rear Remotes - 3 Attachments to Run?
   / 1 Set Rear Remotes - 3 Attachments to Run? #21
Brad, thanks for sending the link again. It opened this time, no issues.
Other than having to buy hoses and fittings for the Double Selector Valve, looks like it would work for my purposes. With it being manuel level operation, it's much cheaper than the multiplier and looks to do the same thing. Is that right or wrong?
Eddie
The solenoid valve I used from Baileys is only $16 more than the lever valve from Surplus Center. Figure another $20-40 for the switch and wires. I paid $25 for my switch from Napa and used some wire I had lying around. Either valve requires similar adapters. Here are the links again for comparison.
Baileynet Solenoid Diverter
Surplus Center - 1/2" NPT 20 GPM DOUBLE SELECTOR VALVE
I recommend the solenoid valve to divert the curl circuit for the convenience of a more natural one-handed operation and the surety of the curl function unless the button is depressed (imagine getting the lever position confused and dropping a load inadvertently.) When I suggested the lever diverter I was thinking of using it to switch the rear remote between implements.
The full kit from Select Plus that DJNebraska posted is a good idea if you don't want to worry about sourcing the small parts. I came in at half the cost of the kit but I spent pretty much a full day putting it together.
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2012 International 4300 Reefer Truck (A56438)
2012 International...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
