1 or 2 wheels on mower?
/ 1 or 2 wheels on mower? #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
I have seen one wheel and two wheels on the back of rear rotary mowers, (shredders not finish mowers) and was wondering what the advantages and/or disadvantages are? Does anyone know? Just wondering... /forums/images/graemlins/confused.gif
/ 1 or 2 wheels on mower? #2
Don, I don't know about the advantages/disadvantages other than maybe two wheels just carrying a heavier load and maybe preventing it from tilting and scalping in some areas. It seems to me that most frequently you see the one wheel on 3-point hitch shredders and the two wheels on the pull behind, and of course the pull behind from the drawbar would need two to keep it level. However, I had a neighbor with a very old 7' 3-point shredder that had two wheels. The wheels and their height adjustable brackets were mounted onto a square tubular length of steel across the back so the entire wheel assemblies could be moved to change the spacing between them. Then one of his boys hung one wheel on a stump and tore it up, and instead of replacing it, he just moved the other wheel to the center and made a one-wheel model out of it.
/ 1 or 2 wheels on mower? #3
The ones I've seen with two tail wheels were normally either bigger cutters or were the tow behind (rigged to the draw bar rather then the 3PH).
I'm sure the bigger cutters neded more support and the tow behind models needed the extra stability.
CHANDLER 500 BBL FRAC TANK (A65643)
CHANDLER 500 BBL...
72in. Fine Low Side Skeleton Skid Steer Bucket (A65640)
72in. Fine Low...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
STEPP SEALCOATING MACHINE (A59914)
STEPP SEALCOATING...
2020 Yanmar Diesel Engine (A65579)
2020 Yanmar Diesel...
