1/10th Hours
/ 1/10th Hours #1
ot2o
Branson 2810
I noticed my hour meter has some text to it that says 1/10 hours. How should I interpret that?
Do I do my maintenance every 50 1/10 hours or do I calculate out how many full hours have pass? My tractor has 500 1/10 hours so does that mean it only has 50 hours on it?
Thanks!
/ 1/10th Hours #2
1/10 of an hour is 6 minutes; for example, 6/10 would be 36 minutes of engine run time.
It's literally just the minutes until the next hour is added to the clock. 🍻
/ 1/10th Hours
So I do have to calculate the minutes into hours then for when to perform maintenance?
/ 1/10th Hours
Sorry so to clarify my question. I have to change my oil every 50 hours according to my owner manual. Does that means every 500 1/10 hours on my meter?
/ 1/10th Hours #7
No, every 50 hours on the meter.
50 1/10 on meter = 50 hours and 6 minutes.
500 1/10 on meter = 500 hours and 6 minutes.
127 7/10 on meter = 127 hours and 42 minutes.
As turnip stated, 1/10 of an hour is 6 minutes.
Just take the first hour number on the meter, then add the tenths by multiplying them, to get the minutes, by 6.
Patrick
/ 1/10th Hours #9
My Kubota registers tenth hours also. I have no idea why. It certainly is not used for any purpose I have.
/ 1/10th Hours #10
1/10 hours on the hour meter serves the same purpose as 1/10 miles or kilometers on an odometer.
To the OP just pretend your hour meter is an odometer. Cars have their oil changed at so many miles, kilometers. Tractors are changed at hours, but your read the meter the same way.
/ 1/10th Hours #11
I think OP is asking how to read his meter. If there's any doubt:
  1. Record time and hour meter reading next time you start the tractor.
  2. Record time and hour meter reading when you turn off the tractor.
  3. Compare difference in meter reading to elapsed time.
Always best to do this when running near PTO RPM, as some tractors count hours proportional to RPM, in some effort to better gauge wear and maintenance needs.
/ 1/10th Hours #12
My guess is , only your rightmost digit is in tenths. All other digits to the left of that one, are your hours
/ 1/10th Hours
Thanks all appreciate the replies.
/ 1/10th Hours #14
For example, my hour meter reads 423.7 right now. That means 423 hours, 42 minutes. Lije someone said for practical purposes you can ignore the decimal.
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A65056)
2017 GENIE GTH-844...
ALUMINUM HYDRAULIC TANK (A68842)
ALUMINUM HYDRAULIC...
2005 Oskkosh MK48A1 8x8 Articulating Tactical Truck w/ MK14 20ft. Flatbed Container Hauling Trailer (A66736)
2005 Oskkosh...
1995 Jeep Wrangler 4X4 SUV (A66738)
1995 Jeep Wrangler...
2015 Chevrolet Express Shuttle Bus (A66736)
2015 Chevrolet...
2018 GMC Terrain AWD SUV (A66738)
2018 GMC Terrain...
